PowerPose - Twist?
I feel kinda dumb, but does the right-click not work for anyone else on PowerPose? When I right-click I get a submenu, not the ability to Z rotate or Twist.
  • TaozTaoz Posts: 10,343
    Works OK here.  But you get a submenu if you right-click on a control point and then release the button without moving the mouse. You must keep the button pressed and then move the mouse.
  • I thought I eplied to this last night. Make sure the pane isn't in Edit mode, by right-clicking on an area away from a dot and checking the menu. Then make sure you are right-clicking on the dot itself not part of the background, and that the dot is for a property that has Twist.
  • jake_fjake_f Posts: 226
    Same issue here.  Right click often does nothing.  I solved it by clicking on the control point in PowerPose, and then twisting in the Parameters pane.  Works well enough for me.  Other than this quibble, I'm finding PowerPose very useful.
  • Leonides02Leonides02 Posts: 1,379
    Ah, now I understand what I was doing wrong. I was clicking away from the dot.
    Thank you.
