Genesis 3 clothes on a Genesis 8 model
Is there a good way to put Genesis 3 clothes on a Genesis 8 model?
Do I need a converter? I saw one that fits Genesis 8 clothes on a Genesis 3 model, but I’m trying to go the other direction...
Any chance it will just fit on its own?
  • barbultbarbult Posts: 27,650
    Autofit from G3F to G8F and G3M to G8M is built in. Just fit the clothing item to G8 and an autofit dialog pops up asking what model the clothes were designed for. Select G3.
  • Never mind. I found a converter from Riversoft Art.
  • It mostly should autofit on its own, but I've had a little bit better results doing this: Load the Gen 3 clothes without Gen 8 selected, or other pieces of clothing. You might be u selecting a bunch of times, but it's worth it. Select all the clothes, then hit the menu button at the top of the Scene Tab (I'm nowhere near my computer right now, so I'm going off of memory). Hit Scene Identification, then Preferred Base. It should be set to Genesis 3/Female right now. Change it to Genesis 8/Female. After that, they should autofit without an issue. Unless it's a wearable prop, like a sword or something. Also shoes tend to be a problem, so you might have to grab some from a Gen 8 outfit if you need them.
