Using a mask to make part of an image chrome in IRAY
William W. Connors
I am still learning my way around IRAY. I have a package to render which needs to have some areas of the surface designated as highly reflective. I assume there is a way to do this similar to the way you can apply a mask to an emissive surface. So...help?
I probably would use a geoshell....
1) get a copy of the UV map of your figure (generally, if you go to your account on the Daz3d wevsite and Product library, you should see the various methods to download your figure and a download for the template, a map of the UV's.
2) Open the the template in an image editor like Photoshop, Gimp etc... and paint in where you want the chrome to be. Duplicate that image and invert the image and fill the non-chrome areas with black and the chrome areas with white. Save as a jpeg or png
3) load your figure, add a geoshell to the figure, apply the default Iray shader to the geoshell, apply the chrome shader to the geoshell and plugin the jpeg you made (a mask) to Cutoff Opacity setting of 100%.
4) Now, you have your perfect chrome bikini!
nemesis10 - PERFECT! Thank you for being so much smarter than I am. I had no idea you could do that!
Not smarter... just older.... One thing which is not intutive but makes great sense when you think aabout it is that a geoshell inherits the uv of the object it is created from.
