DS Feature Request: Export only selected item(s)
Wouldn't it be nice if the Export utility in DS had the option to export ONLY the selected item(s). All too often, I find myself wanting to export an object/figure as an obj file so I can load it in as a morph using Morph Loader Pro. Unfortunately, before I can do this I have to go through the scene deleting/hiding everything I don't want to export. It would be a lot quicker and easier to export only what I DO want to export by selecting it. This option could be added to the Export popup window as an option button.
Already possible via script - see http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/export_obj_silent/start
Richard, thanks for the reply. Good to know that there is a solution, in theory at least. The next question would be how to use the script within DS? I know nothing of scripting.
I could never get this to work. It always exported the whole scene
Have you changed the relevant boolean values in the block of code:
This illustrates my point exactly. If DAZ3d will not add this function to DS, then there is an opportunity for a programming savvy PA to produce a one click solution via an appropriate (fully functional) script.
