Setting up Basic Materials for Genesis Figures
Dartanbeck
This is an article I've written for my website that isn't launched yet so I'll just post what I can here in the meantime.
This is just a small part of a much larger topic - but in the forum, it should work pretty well just on its own.
I wrote this to help new Carrara users and Carrara users new to working with Genesis in Carrara. Please pardon me if I get a bit too basic, but I wanted to attempt to make it clear enough for everyone, no matter their experience level. I don't have a lot of time right now, and I haven't read this in quite some time, so I may have to edit it later, but the gist of things should help quite a bit. Here we go!
Post edited by Dartanbeck on
Setting Up Materials - Basic
Introduction
Carrara is developed to allow us to load in and work with Poser and Daz Studio formatted props and figures in ways that other 3D software applications simply cannot.
We must try to remember that this does not mean that it is made to work exactly like the applications these products were originally intended for.
While we may have to adopt some work flows to get the content working correctly, the fact that we can get this content into Carrara intact with morphs and rigging working as it should is the magic part that we should all be thankful for.
One of the biggest differences between any 3D applications are their render engines. This is why material settings made for one application will not apply correctly to another. So our biggest hurdle to overcome will be getting our Shaders optimized for Carrara - which Carrara makes very easy to do as you’ll soon see.
Daz3d has taken additional steps to make sure that their default character materials translate over to Carrara on a level that looks fairly decent so we can easily get the wrong impression that all shaders for Daz Studio should work just as well.
In truth, many after-market shaders made for Daz Studio do not apply well in Carrara.
Don’t let this bother you. As we get used to working in Carrara, we learn our own ways to make these procedures very simple to perform.
There are other things besides Material Settings that may not work as expected - or even at all - when brought into Carrara. Keep in mind that what we’re trying to get into Carrara is not a Daz Studio scene, but a rigged figure with working morphs and textures. Everything else in the scene should be set up in Carrara itself.
So it’s good practice to first bring in Genesis alone, and get it set up just right and saved, before bringing in other elements. Then we can continue this same process with everything else as we bring those elements into the scene.
UV Coordinates for Genesis in Carrara
When we bring in the Base Genesis model from the library, it comes in without textures. If we instead load in one of the versions found in the Characters section, they come in with their basic color maps in place, and they load with the UV Mapped Coordinates for that specific shape. This can be important to know if we wish to use a specific set of maps - no matter the shape we want to end up using.
Basic Female comes in with UVs that match Victoria 4 texture maps. Basic Male is the same for Michael 4 maps and Basic Child for Kids 4 maps.
Knowing this, let’s consider that we want to use (for example) the Troll maps on a shape of a small girl child.
To do this easily, we’d start by loading in the Troll character preset so that the maps line up. Remember, we want to use Troll’s maps. Those maps were made to fit the custom UVs of the Troll shape.
So we begin with the Troll character preset and then change the shape to anything we want. In this case, remove the Troll morph, and add some Female and Child morphs to our liking.
In this same idea, we can use Michael 5 maps on a Troll or Gorilla or on Victoria or whatever shape we want. We just want to begin with the base character that corresponds to the maps we want to use - and then change the shape to whatever we want.
It’s important to do this or we’ll end up seeing map irregularities on the figure, like the outside of the map, etc.,
The figure here shows the Troll maps loaded onto the basic Genesis. Notice how the maps don’t line up with the figure. This is what I’m talking about here. If we want top use the Troll maps, begin by loading the Troll character preset. This will give us the proper UV Mapping for those textures. Now we can change the shape to anything we want, and the mapping will follow.
Daz Studio has a built-in function which allows users to swap UV Mapping directly while working but Carrara does not. So the simple work-around is to just load in the preset character according to which maps we will use.
Workflow Efficiency
In fact, we have the same number of shaders as we have material zones in Genesis plus one, which is the Default Carrara shader.
As with all Daz3d figures, several of these material zones (also called Shading Domains) will use the exact same shader. Carrara automatically gives every material zone its own shader - every time we load something.
Now go to Edit > Remove Unused Masters > Consolidate Duplicate Shaders
It is important to perform this operation before we make any changes to any of the shaders.
(Image on right - Before Consolidate; Image on left - After Consolidate)
While we can easily copy and paste an entire shader into another, we want to reduce the actual number of shaders we have in our working scene to the lowest number possible. This is not to say that we should feel nervous about adding more shaders. We’ll add a new shader any time we need one. But texture maps for figures can be quite large and we don’t want to multiply those (to our computer’s memory) unnecessarily.
Every time we load in a new piece of content: Edit > Remove Unused Masters > Consolidate Duplicate Shaders
Get used to that. It’s also helpful to remember to select the other two options in that menu when appropriate: Remove Unused Objects and Remove Unused Shaders
Note that Carrara will never purposefully delete it’s own Default shader. There must always be at least one shader in any scene.
Everyone has a different view on what an optimized shader is. Basically, if we’re happy with how the Basic Male looks when he’s loaded in from the library, our journey to optimizing will be quick. This is a very basic, but well performed optimization that the Daz3d Developers have built into their Daz Studio shaders - knowing how they will translate into Carrara.
While I’ll be using Basic Male in my example, the same applies to the Base Daz3d character presets. Quite simply, there are certain aspects of any material setting in Daz Studio or Poser that will never transfer perfectly into Carrara when being loaded in. This cannot be helped.
So the developers looked at how Carrara is converting the materials over, and designed their base Daz Studio shaders to make for a good cross over - which I think is really cool.
For more realism, however, we have at least one more map to add to some of the shaders, and want to set things up to work more like the real thing. We cover that in the More Advanced article.
Lets look at the simple setup and advance in the next article. That way those of us whom are happy with the simple setup have less to read, and it also helps to explain where we’re going with the more realistic options later.
By the end of this Basic Shaders discussion, we’ll wrap it up by making a full-figure (Multiple Zone) preset that can add this optimized shader set to any figure of the same base mesh (Genesis, for example) as well as how to create individual shader presets to add these settings to ANY figure period.
It should be said that we’ll need to load a figure for this exercise which comes with texture maps. Genesis base figure does not load with maps. So we need to load Basic Male, Basic Female, Basic Child, Genesis 2 Male or Genesis 2 Female, etc., It can also be Gorilla or Troll or Michael or Victoria, Gianni, Gia, etc.,
For a full understanding, however, please refrain from loading in a third-party character preset. As with Carrara artists, Daz Studio content artists enjoy thinking outside the box to get their shaders to be special, and that sort of thing doesn’t often translate to Carrara, often leaving your figure all black or something odd.
We’ll get to how to load in your third-party characters in the Advanced section. For now, however, it’s best to start with one of the Genesis (1 or 2) standard characters.
(Image on left - Genesis 1 Basic Male, No shader changes)
After we’ve performed the Edit > Remove Unused Masters > Consolidate Duplicate Shaders, let’s take a look at one of the skin shaders.
Select “Actor” and go to the Texture Room so we can see what’s getting applied to what. When asked if we want to Create a New Shader or Edit the Existing Shader, choose Edit Existing, so that all Shading Domains get updated, not replaced, starting with a new, blank shader.
Skin
The top domain (using our Basic Male example) is the skin shader for all of the limbs, so let’s double-click that one to open it up.
The reason that these basic shader conversions work so well is that, as we can see, we’re actually only left with a Texture Map in the Color channel of the Shader setup. Everything else is either set to None, Black (same as None) or, in the case of Shininess, is irrelevant due to another channel being set to None - in this case, None in Highlight makes the Shininess channel ineffective no matter what it might be set to.
So at this point, let’s take a good look at which Shaders are in which Shader Domains.
For now we only want to seek out the three main Skin shaders. One is for the Limbs, probably now called Fingernails, Legs or something similar. One is for the Torso, probably called Nipple or something like that. Finally is a shader for the Face, probably called Lip or nostril or something like that.
I like to take this time to switch back to the Assemble Room, go to the Shaders tab of the Instances Tray, and rename those main skin shaders to “Face”, “Limbs” and “Torso”, but it’s not necessary.
This just makes things easier for me in the long run. Daz3d actually uses a prefix to further organize shaders, keeping all figure shaders together. So I often retain the prefix and name them “1_Face”, “2_Torso” and “3_Limbs” for example.
Select Actor and go back into the Texture Room
I’m looking at Genesis Basic Male, so the next shader from the top that is not one of the three major skin shaders is the Eyelashes. Open it up.
We see a similar thing here, except that the Color is actually just a color and the only Texture Map being used is for the Alpha channel.
Eyelashes and Shader Cleanup Notes
In the Alpha channel, a Texture Map is being Multiplied by a Color of pure white, which is the same thing as multiplying it by a Value of 100, which is redundant and unnecessary. It might add a tiny fraction of a fraction of a second to the render engine to go through this extra calculation.
It’s such a small thing that it really doesn’t hurt anything to leave it the way it is. But I like to clean these things up.
To do so, simply drag the Texture Map onto the main channel to which it belongs - in this case: Alpha (<< image on left). This will eliminate the entire Multiply calculation, leaving only Texture Map in the channel.
(Image on right - after dragging the source containing the Texture map onto its respective channel >>)
To keep things easier to see at a glance, we may also find it beneficial to replace any color of pure black or Value of 0 with “None”. To check to see if a color is pure black, I click the color chip and look at the three values in the color wheel dialog box. Black has only 0 (zero) in each of the three values.
Other times, if I want a bit more control without introducing any color, I might use Value of 0 instead, so that I have a slider at the top level of the shader. Nice and easy to adjust.
If we wish to keep color possibilities readily available, we can leave a black color chip in the channel. To raise the value as if we were sliding up the 1 - 100 slider, open the color chip and enter a value into the middle value setting (L).
Those three values are for Hue (H) Level (L) and Saturation (S) on the HLS scale.
Hue determines the position around the circle of the HLS wheel. As the Saturation level increases, it is Hue which determines which color the color will be.
Level determines the value between black and white. This sets the overall brightness of the color.
Saturation determines how far away from gray scale the color is to appear. The higher the value, the more colorful (saturated) the color appears.
Eyes - Sclera, Pupil and Iris
Here is a situation where our individual needs might require that we use individual shaders for individual parts of the eye. I’ll cover higher-end Eye shaders in another, more advanced tutorial.
In Basic Male Sclera, Pupil and Iris each have their own individual shader.
For a fine Basic setup, all three of these can use the same shader.
To do this, simply drag the Iris shader onto the slots for Sclera and Pupil in the list of Shader Domains. Here is a situation where we’ll end up with two unused shaders in our Shader list. In the Assemble Room, Edit > Remove Unused Masters > Remove Unused Shaders will clean these up.
Now lets open the Iris shader.
Perfect. We have a Texture Map in the Color channel, everything else is turned off. This is perfect for most situations on the basic level.
It is common for people to add shine to these parts of the eye. Don’t. We’ll add the shine next.
If we scroll down the list of Domains, we’ll see that we’ve also just edited the shader for Lacrimal, which also uses the Iris shader. If it isn’t set to the Iris shader, do so using the drop-down on the right side of the domain’s shader listing.
Eyes - Cornea, Tear and Reflection
Basic Male (Genesis 1) doesn’t have the Eye Reflection domain but I’ve included it here for Genesis 2 users.
In most situations, I treat Cornea and Reflections layer with the same shader, keeping a separate Tear shader to allow for control of the visibility of the Tear separately.
This one is really simple, and is where I’m going to have you switch from a simple shader conversion to using a Carrara shader preset. This particular part of the eye is important enough to dictate that we use Carrara’s render engine to help us out.
Open the Cornea shader. Now go to the browser’s Shaders tab and scroll down to find the Glass presets.
With the Cornea shader open, drag the shader preset called “Clear” in the Glass presets onto the where it says “Top Shader” in the Cornea shader window.
I say “basic” because it’s a very basic way of setting up a simple substance within Carrara without going into heavy technical accuracies and experiments. “Advanced because we’re adding more of the powerful shader functions, like Refraction.
In the Domains list, drag this Cornea shader onto the Eye Reflection domain if you have one, or select it from the drop-down.
Open the Tear shader and drag the same “Clear” shader preset onto its Top Shader. With the shader still open, reduce the Highlight slider to 0 to remove the tear and increase it to 100 to make it very highlighted. This can really help to add emotion to expressions. Even tears of happiness can get nice and glossy - and increasing the Highlight value will increase the shaders glossiness.
If you like, have a look around in the glass shader preset. Notice how Carrara isn’t using the Alpha channel to reduce visibility. Instead, we’re using Transparency to allow light to pass through the material, allowing highlight and shininess to do their thing!
Reducing levels of Alpha makes the whole shader disappear, while increasing intensity of Transparency doesn’t remove our ability to see the shader, it instead allows us to see through it, except when our vision is blocked by highlights or reflections.
The surface is further enhanced with Refraction and Reflection.
It is common for folks to feel a need to increase reflection to make things shinier when, in fact, we use Highlight and Shininess for that. Reflection is a more intensive calculation which can actually hide what we really want to see, if overdone. I often keep Reflection of my Cornea shaders really low: between 2 and 3.
What we’re actually looking for is often just more highlight and/or a tighter (higher value) shininess. We also need to be aware that too high of a value in Shininess can reduce the highlight to such a tight angle that it will not show up in the render. Much over (or even up to, in some cases) a value of 35 can often be too much. But for these eye surfaces, we can even go up to and over 50 for a nice shine on the eyes. It really depends on out lighting and render setting, so adjust this to your own taste and settings.
I love having Refraction on my Cornea shaders for those times when I can catch a view of the eyes from their side, showing off a cornea bulge - a morph I always use. The refraction is what keeps this clear material form being empty. It uses the angles of incoming light against surrounding nearby colors to create an effect very similar to how real eyes look at these rare views - especially when the light flows passed the eyes just right!
Mouth - Gums, Teeth, etc.,
In many cases, especially in Basic situations like this, I like to use the same shader for all inner mouth domains. I usually rename the Gums shader to Mouth, and make sure that all of the inner mouth and teeth domains are using this one shader.
We’ll treat this like shiny skin and, since the teeth are mostly white, their contrast will have an automatic hardness change to their appearance in our basic setup.
To get the right color of shine in the right places, let’s introduce something that I wasn’t going to cover until we get more advanced:
Hold the Ctrl key down and then drag the Texture Map from Color to the Highlight channel
Holding Ctrl while dragging will copy the dragged item and paste it where we release. Now we have the texture map used in the color channel in the highlight channel. Now we’ll set the Shininess channel to a Value of 25, which will make the elements of the inside of the mouth quite shiny.
If it’s too shiny for your liking, try lowering the shininess to something like 15 to 18 and then changing the Brightness slider under the Texture Map in the Highlight channel to 75, lower the brightness by 25% and test render that.
A Fine, Basic Shader Setup
So here we are! We’ve got our basic shader setup, Save your work and try some test renders using different poses and expressions. Before I call a Character complete, I like to open the mouth and show the teeth, turn the eyes with them open wide and take some test renders close to the face, and some backed off showing more of the whole figure.
Knowing that I’ll be doing this, I duplicate my Camera, which is usually focused on the figure from the thighs up at this point and, while looking through the new camera, select the head of the character and type 0 (number zero) to zoom the camera to the head, then back it off a bit to see the top of the head through the top of the chest - a nice close-up on the face, often at a slight angle.
Then I can switch between the two cameras quickly in the render room.
Again... when we get this just right, Save it so we can always come back to it! ;)
Saving Shader Presets
I like to always test my shaders using lights similar to that which I often use in all of my character scenes. I have another article regarding my Simple Character Lighting Setup if you’d like advice on such a thing.
I find that it really helps with consistency of accurate shaders if they’re all made using a similar lighting and scene setup.
Once I have my shaders how I like them, I’ll often save them to my browser so that I can save time setting up my next character which uses the same base figure.
I also have an article about setting up a custom browser, if you need help with that.
To save shaders, I use two methods: the first being a Multi-Shader Preset, which saves all of the shaders of the figure in all of the domains, exactly as we have it set up.
For this type of preset to work properly, we need to use the same Base Figure. Even if the base figure uses different UV Mapping coordinates, the preset will still work, we’d just need to change the maps if it’s a figure that uses different UVs.
But what if we worked really hard to get a really nice skin shader, and we want to use that on a figure that has entirely different domains?
This is where I use my second method: Saving individual shaders to the browser.
Both methods have their advantages. The Multi-Shader Preset is great if we’re only using one base figure. But let’s say that we have a Multi-Shader preset for a Genesis 1 figure and try to load that onto a Genesis 2 figure - it will place the wrong shaders in the wrong domains, and some domains won’t get anything at all - because the different base figure has an entirely different set of domains, in an entirely different order.
No matter which Base Figure we use, a well made skin shader will work well on any figure, as long as we replace the Texture Maps with maps that are made to fit the UV mapping of the figure we’re using. The rest of the shader remains the same, and works the same as it did on the other figure!
So this is where the individually stored shaders work great!
Both methods are simple:
Multi-Shader Preset - in the Texture Room, drag the big multi-colored ball at the upper right of the screen into the appropriately opened portion of the Shaders tab. (see the Custom Browser article for more info) - Give the Multi-Shader Preset a name, and that’s it!
Individual Shaders - From the Assemble Room, drag a shader from the Shaders tab into the appropriately opened portion of the Shaders tab. (see the Custom Browser article for more info) - Give the Multi-Shader Preset a name, and that’s it!
I hope you’ve found this article to be helpful. Keep in mind that this system will create very fast and simple shaders for your characters to get you up-and-running as quickly as possible.
For much better rendering results of vastly more realistic-looking people, we need to advance into further areas of the Shaders. It’s not hard at all... it just requires a little more time and effort from our part.
The beautiful thing is that the wonderful Artists whom create these character products already give us all of the tools we need to proceed, and Carrara takes all of the guess work out of setting everything up... so what are you waiting for? Head over to the “Setting Up Materials - More Advanced” article and get to work on your next perfect being! ;)
That's it for now. Feel free to comment/question... let the discussion begin ;)
I'd like to add that, I really enjoy trying to have a groove to how I work with shaders, so that I can edit materials for vast scenes that require a lot of edits without a lot of trial and error - so I'll spend hours getting those trial and error sessions out of the way, and use what I've learned as a quick way to get good, basic edits done.
Afterwards I can come back to specific materials that might require special attention.
I have a good groove going for hard surface materials that have maps appropriate for Iray included. That will be another article entirely. While I'm still in the trail and error phase of that, I've been getting really cool results from my speedy groove that I've come up with so far. I feel that some materials that are highly metallic may still be a bit too reflective and shiny using my current method, so I intend to tweak it down a bit more before I complete the article.
That said, I have done a lot of work with skin and eye shaders since I've written the above article, so it will be interesting for me to read it again - but again... this article (above) was intended to quickly get simple results that aren't looking all wrong in your renders - just a way to make Genesis figures lose their issues within Carrara.
While in Carrara, I've become a fan of getting to know Texture folders as opposed to getting to know where Material Presets are located in a library. For example: if I buy texture upgrades for something, as soon as I install it with DIM, I look in the "Installed" tab, right-click on the upgrade pack and "Show Installed Files" if I'm not sure which folder to look in.
Then I choose to explore the folder. Look at all of the suffixes after the images to identify anything special. Like "a" in modern PBR nomenclature tends to mean "Ambient" which in PBR terms seems (to me) to mean Emissive. So I know to use those maps in the Glow channel in Carrara. But I often find that I need to multiply the _a map with the main color map that goes in our Color channel.
Anyway, knowing where maps are, and what maps are available for us to use, allows us to really get creative within Carrara, especially now that the fine developers at DAZ 3D whom worked on the updates to 8.5 added Photoshop-style layers using the MultiLayer shader option. Again... more on that later. Okay... I gotta go... NOW! LOL
Cheers fellow Carraraists! ;)
Superb work
thank you Dart, you are a gem, this is so helpful. Should be stickied :)
PDF form just in case :)
Cool! Why didn't I think of that?!!! LOL
Thanks! ;)
