Daz Studio 4.6 (Create Clothing Button) / Marvelous Designer
Hi friends,
I am using Daz Studio 4.6 program. Problem, I want to transfer outfit. Daz (Create Clothing) Button no. What is the solution? Please, help me.
I looked at a few topic. But I could not find the solution. :/
  • Richard HaseltineRichard Haseltine Posts: 111,984
    That was a beta feature that was not developed. You would need to use the Transfer Utility - Edit>Figure>Transfer Utility, set the Source to the figure the clothing is for, set the Source shape to current if you used a morphed figure in MD, set teh Target to the imported OBJ file, and then click the Show Options button and check the Reverse Source Shape from Target box. Then click Accept.
  • edited December 1969
    Thank you. Yes, this is the solution. That feature will come back? Otherwise, you will continue like this?
    I don't know, but since it has been gone for a while I suspect the make Clothing function is permanently gone. Sorry.
    I get it. Thank you for everything. The problem has been solved.
