Does "Wet and Tanned Skins for G8F" only work with certain anatomical elements products?
Hi,
I have the product below
https://www.daz3d.com/wet-and-tanned-skins-for-genesis-8-females
On a default G8F body the bikini tanline i want to use looks ok.  For the Golden Palace for G8F the material transfer utility that comes with GP works fine.  However i dont want to use GP because i cant get it to look the way i want.  The genital product that i want to use is 3feetwolf's New Gens for Victoria 8 however the transfer material utility that comes with the wet and tanned skins is messed up.  The tan lines between the G8F and the NGV8 doesnt line up.  And on the NGV8 between the anus and vagoo there is a straight horizontal line where on the side towards the front of  the character is untanned but to the rear of it is is tanned.
Edited by a mod to adjust title
  • I would expect the transfer script to be intended to work only with the Daz anatomical elements - if it works with others they presumably have the same surfaces and UVs, which would be surprising if they are independent models.
  • LeanaLeana Posts: 13,498
    edited February 2019
    I don't know how the product you want to use is mapped but I've read that some 3rd party genitals use the torso map as a base for the skin. If yours does that then it's not surprising that you get weird results when adding tan lines to the torso...
    Post edited by Leana on
  • Yah it was weird...when i opened it up in Blender the UV map for the gens was for the Daz torso, but it was linked to its own texture map which was just the size of the gens. I fixed it by assigning the torso texture to the gens since thats what its uv map is set for.
  • hansolocambohansolocambo Posts: 649
    edited April 2020
    I'm trying right now the "genitalia Female Transfer" of wet and tanned but my Genesis' Genitals (the official ones, not third part graft) remain : white... Any idea ?
    Post edited by hansolocambo on
