Error applying G8 material to G3
I'm trying yo apply a G8 Thistle Texture to G3 Bucky (from Rendo) but I keep getting this error:
An error occurred while reading the file, see log for details
The log entry is:
2019-02-02 11:49:00.337 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2019-02-02 11:49:00.339 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2019-02-02 11:49:00.340 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2019-02-02 11:49:00.341 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2019-02-02 11:49:05.463 Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
2019-02-02 11:49:05.463 Error reading file, see log for more details.
If I apply the textures to G8 and transfer tham one at a time, they look fine.
I can apply G3 textures to G8 with no problem.
Is there something I can do to convert these files?
  • Hierarchical presets must be applied to the correct base figure. Once applied to Genesis 8 Female, you can save a regular Materials preset whch will work with other figures with the correct surface names (as Genesis 3 Female has).
  • pwiecekpwiecek Posts: 1,598
    edited February 2019
    Does a hierarchical preset mean that it is for a scene that contains several items like Thistle, the tail, the whiskers etc.?
    Thanks for the info
    Post edited by pwiecek on
  • In this case, I would expect so - a Hierarchical preset applies to some or all items parented to the base figure, and may also affect the base figure (it has to be a figure at the root for a hierarchical preset to save)
  • LeanaLeana Posts: 13,334
    With a lot of G8F characters the problem is simply that it's a preset intended for G8F and the G8F eyelashes (lashes are a separate item for G8), which would cause the problem when used on G3F.
    Post edited by Leana on
