Daz Environment animateable?
surody
Is it somehow possible to animate the environment in Daz Studio to achieve a day/night cycle?
Are there scripts or does anybody know a work around? Thank you in advance!
you can try Casual's scripts and animating the lighting, if emissive the shader might be animateable with matanim
https://sites.google.com/site/mcasualsdazscripts/
https://sites.google.com/site/mcasualsdazscripts/matanim
Yea thank you, I got this script, but I was hoping to animate the sun in Daz Studio.
well make a light a sun node and animate that in position
I never tried seeing what happens if it is below the horizon
Just a heads up! Every surface property for aweSurface is animateable out of the box, no extra scripts needed;) Animating a sunrise should be totally doable.
https://www.daz3d.com/aweshading-kit-10-for-daz-studio
https://www.daz3d.com/forums/discussion/280441/awe-shading-kit-for-daz-studio-and-3delight-commercial/p1
https://www.daz3d.com/forums/discussion/277581/awe-surface-shader-a-new-physically-plausible-shader-for-daz-studio-and-3delight/p1
It saves the animation along with the scene or I have to reapply the animated material at every scene load?
You can use http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/start#post-load_callbacks to show how to use a script to link the proeprties to a proxy prop, which does have animatable properties (this is how IBL Master was made to work).
Saves with the scene.
Edtit: Sorry no, I was wrong:( Have to look into that!
Ok wowie came up with a workaround, which is a bit fiddly, but doable:
