Does anyone know if this product supports iray?
ac_mr_blondeac_mr_blonde Posts: 102
https://www.daz3d.com/mishka-hair-g2
I can't tell if it's 3delight or iray, and it's kind of old, so I'm wary of assuming.
    Pretty sure it only comes with poser- and 3DL presets. You can ask for a refund if that's the case and you're not willing to convert it;)
  • FSMCDesignsFSMCDesigns Posts: 12,855
    Nearly every product in the store that has textures will work in Iray, although you may need to tweak a few settings because non iray items tend to come in with the glossy turned up to high, easy fix. As Sven mentioned, if it doesn't work that way you want, just get a refund.
  • SimonJMSimonJM Posts: 6,100
    edited January 2019
    Just tried it and ... I swear I rported it and it got fixed when it was sold at RDNA, but the transmap get screwed up on the tips of the hair, but nothing that a bit of manual intervention cannot fix.  Also, does not seem to be any metadat with th eproduct so you'll need to browse through content library to find it.
    Only Iray materials are on the G2F
    800 x 1318 - 276K
    Post edited by SimonJM on
    Just for info, I have just submitted a ticket for this issue.
    I always use the content library to select items, so no need for any metadata here. Thanks for the image, cool hair, might have to pick it up.
  • Moved to Technical Help since it's a question,, not a Product Suggestion.
    You got that with just the uber shader or did you do some manual adjustments beyond fiddling with the transmaps?
    Didn't fiddle with a thing (beyond fiddling with the transmaps),letting Daz Studio do any shader conversion itself.
    Will have to buy the hair then. Always looking for good hair.
    Just got a response from Support, they are not updating content brought across from RDNA and found some othher rissues wit this hair and will be disabling it from the site.
  • Thanks for the info!
