Portion Of Frames of Video Renders Coming Out Completely Black
This has been driving me crazy. Each time I render a video, there's like a 20 to 30 percent chance that part of the video will come out completely black. Latest episode of this had the first 1sec coming out completely black and the last 2 seconds rendering fine. Then when I render it again without changing a thing, it came out fine.
See attached thumbnails below.
Sometimes it's reversed with the first part coming fine follwed by the remaining video rendering black. Anyone else have this happening?
666 x 631 - 411K
666 x 631 - 609K
Post edited by mechengineer97 on
What happens if you render to an image sequence instead?
Thanks for the reply. Never used image sequence, is there an advantage using a sequence instead of movie mode?
Several - you get an alpha channel, which can be useful if you are combining with other elements; you can tweak and rrender a few frames if there's a problem, instead of having to rerender the whole sequence; it allows more choice of output format, depending on what your video editing software supports; it allows the addition of a soundtrack; it provides crash-protection - just pick up from the last good frame.
