How to remove Legacy UVs for Genesis 8: Victoria 4?
I put Legacy UVs for Genesis 8: Victoria 4 on my character. It loads a white character with purple geografts. I decided I didn't want to use a Victoria 4 skin after all and deleted the geograft but I can't get rid of the white skin/shader. I made a materials preset file of the original base genesis 8 female skin and used it but it the skin loads overtop the white shader, doesn't get rid of it.
Any help is appreciated. Thank you
  • dracorndracorn Posts: 2,379
    Hmm.
    It sounds to me that the preset file may not be loading correctly.  I just ran through an experiment where I loaded the geographs and then deleted them, leaving the white skin.  I then loaded the material set from a random G8 character and everything loaded fine.
    Perhaps load up the materials from another G8 character and then apply your preset?
  • Noah LGPNoah LGP Posts: 2,617
    edited January 2019
    Check the UV set is back to "Basic Female" instead of "Victoria 4" for all the surfaces.
    Post edited by Noah LGP on
