is there a way to fit Genesis 3 Hair to Victoria 4.2 figures?
CO3DRCO3DR Posts: 163
Within the Genesis line, if I generally try to fit more advanced hair to a less advanced figure, I get a warning, I tell it I want to convert it, and generally it fits pretty well or I can figure out how to adjust it.
But, I just tried putting Genesis 3 hair on a Victoria 4.2 figure, and I can't get the hair to the right spot. I know I COULD replace the Victoria 4.2 figure with a Genesis 3 one and the hair would probably fit fine.
Is there any product that builds an invisible Genesis 8, Genesis 3 or Genesis 2 shell around a Victoria 4.2 figure that's already in the scene? Failing that, is there some simple adjustment that can attach the hair to the figure in the right place? (Y-Translation on the hair didn't seem to make any difference)
752 x 375 - 321K
  • LeanaLeana Posts: 13,627
    edited January 2019
    Don't fit the hair to V4, just load it. Use translation / rotation / scale / morphs to position it at the right place on V4 head (with V4 is in default pose), then parent it to V4 head.
    You may need to adjust it a bit again once the figure is posed.
    Post edited by Leana on
  • Noah LGPNoah LGP Posts: 2,617
    edited January 2019
    ... and dForce ?
    Post edited by Noah LGP on
  • dracorndracorn Posts: 2,384
    You will also retain morphs this way, and the hair will not deform with a different shape.
    Reverse this method and you can fit V4 hair onto the newer generations.
