Alexandra 8 Issue
When I load Alexandra 8 HD and apply any pose, the upper eyelash becomes offset. In the default pose, the eyelash is fine. I've tried numerous poses, made sure there are no facial expressions/additional morphs applied, and the upper eyelash still breaks. Anyone else noticing this?
Left Image = default pose
Right Image = any pose applied (notice how the upper eyelash is not flush with the eyelid).
1104 x 736 - 246K
1051 x 709 - 202K
  • When I load Alexandra 8 HD and apply any pose, the upper eyelash becomes offset. In the default pose, the eyelash is fine. I've tried numerous poses, made sure there are no facial expressions/additional morphs applied, and the upper eyelash still breaks. Anyone else noticing this?
    Here is how you fix that. Select her eyelashes. Look at the parameters tab for the eyelashes. Click on the menu icon at the top left of the parameters window. Select "Show Hidden Properties". Back in the parameters window, select "Currently Used". This will display all of the morphs currently active on the eyelashes. Look through those morphs. You will find some morphs pertaining to limb twists, bends, stuff like left forearm twist, etc. Set all those morphs (which make no sense being in eyelashes and are indeed BUGS) to zero.
    This should fix the issue with the eyelashes.
  • ArgleSWArgleSW Posts: 161
    Thanks! That did it. It was all the hidden forearm bend parameters like you said. Thanks for the reply. I would have never thought to try this.
    @AnotherUserName have you submitted a bug report about that?
  • Thanks! That did it. It was all the hidden forearm bend parameters like you said. Thanks for the reply. I would have never thought to try this.
    Glad to help. the same issue drove me crazy for awhile. Eventually, navigating the bugs will become second nature.
    No I have not. I figured that this had to have been an old bug and I simply needed to re-install Alexandra and all would be well. Apparently not.
