Bryce 7, Windows, installs. appears to launch, and hangs
When I run "Bryce Lightening 7.0 on Windows I get a small blue widow (screen capture attached) with a list starting with "Local Name, Local IP....".   Nothing else happens.
I paid $19.95 on daz3d.com and downloaded two Windows files :  BryceProContent_7.0.0.19_Win.exe        and     BryceLightning_7.1.0.109_Win.exe
I infer these are two separate versions of Bryce.  I get the same results after installing each one.   What do I need to do?
303 x 439 - 21K
    edited January 2019
    OK    Bryce lightning is only needed if you are going to set up a render farm.
    Install this first
    this is the Bryce Program file.
    Then install the Content files    Do not let one content file remove the other.
    Post edited by Chohole on
  • HoroHoro Posts: 11,689
    Bryce Lightning is the Network render client and can be installed in all computers in your home  network, if you have at least two computers on you network.
