Bryce 7 Install Failure
storm5510_bafbf14a33
I am having a problem with Bryce 7 Pro on the install. This is on Windows 7 Pro (x64) It's showing a dialog I have never seen before. The exact text reads:
C:\Program Files (x86)\DAZ 3D\Bryce7\Bryce.exe
The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxstrace.exe tool for more details.
I looked in the event logs and nothing relative is there. Sxstrace does not cooperate. I unstalled it, twice, and did two system restores, farther back each time. Nothing works. Any assistence would be helpful.
Thank you!
I am going to move your post over to the Bryce Forum
At the top of the page there you will see some Sticky Announcement threads, one of them give details as to how to sort that out.
It is very Common with Bryce installations on computers that are built as 64 bit computers and have lost some info that Bryce needs.
I'm sorry. I cannot find what you are referring to...?
https://www.daz3d.com/forums/discussion/7516/help-bryce-7-pro-crashes-on-launch-side-by-side-error-windows-error/p1
This post in particular https://www.daz3d.com/forums/discussion/comment/98027/#Comment_98027
Thank you for the reply. I found the solution by doing a general web search. Reinstall vcredist_x86. It runs fine now.
