Laura 3 to David 3 question
Hi, I wanted to export a Laura 3 face morph to David 3 in Poser. I exported it as an obj and then loaded as a morph target for David 3's head and it seems to load, except when I dial it up to 1.0 David's head descends into his chest, at the exact height as Laura 3 would be on her body. Would anyone have any ideas on why this isn't working correctly? Thank you for reading this question.
  • fixmypcmikefixmypcmike Posts: 19,740
    Make sure Laura is scaled to 100% before exporting.
  • edited December 1969
    Hey thanks for the reply. The scaling for the body is set at 100% so I don't think that is it. I figured out how to morph the whole body into a copy of Laura 3 as an FBM, so I'm happy with that, a little bit! Baby steps.
  • Richard HaseltineRichard Haseltine Posts: 111,996
    It is working correctly, that's where the head is. If you want it to work you will need to line the head up with David's head before exporting as OBJ, though there will probably be a bit of roughness whatever you do.
