White Wedding Outfit material problem
in The Commons
I just tried out the "dForce White Wedding Outfit for Genesis 8 Female(s)" product and I am getting an error when applying some of the materials. I select the gown in the scene and apply white wedding 01 material with no problem. All other materials for the gown give me a pop up saying Error reading file, see log for more details. The log says: Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
Any suggestions that I can try before submitting a bug? I tried the surfaces tab and selected the material under presets and get the same error. Thanks
Steve
Do you have the outfit parented to the Genesis 8 Female figure? Hierarchical presets, which allow several items to be changed at once, require that the targets be parented to the figure they were made for. If you are wanting to use the dress AutoFit to another figure, try parenting it to Genesis 8 Female (this can be separate from the Fit to target), apply the preset, then reparent to the new figure and save a new Hierarchcial Materials preset (or a regular Materials preset for each part) for future use.
Thanks Richard! I parented the gown to G8 and all works.
