Possible To Select The Dome In iRay?
Is it possible to make the dome selectable like you would any other object in the scene such as a spotlight or character?
  • No because it is not a node in the Daz Studio scene.  The dome is just a set of parameters passed to the Iray render engine.
  • EtriganEtrigan Posts: 603
    What did you wish to accomplish once selected? In the Render Settings > Environment, you can rotate and adjust the positioning, You can change the intensity and other features.
    I was just working through how to render an hdri environment fully with canvases. The built in "Environment" canvas only renders the horizon upward leaving everything below black. I have found a few LPE's that I can try to manually add to see which ones work from some nvidia documentation.
