Where to direct DIM to install items in DS?
I had this set up for some time, and working fine.
Now I have to make changes, and I need to determine where to install items into DS.
As it has been so long since I have done this I need to make sure I am on the right track.
I originally installed DS using all the defaults, etc.
Thanks.
  • So are you wanting to chnage the locations, or just to install using the defaults?
  • BendinggrassBendinggrass Posts: 1,385
    I want to install using the defaults.
    I did a standard install of DS long ago, and so DIM was set up long ago also.
    I changed the settings of DIM because I was having problems, and installed items from inside DS.
    But now, I realize there are so many DS items needing to be updated that DIM is the best way to do it.
    Thanks again.
  • OK, the default path for DIM (on Windows) is
    C:/Users/Public/Documents/My Daz 3D Library
    the defaults for DS, in addition to that, are in your documents folder, wherever that is when you installed DS (default is C:/Users/YOU/Documents)
    Daz 3d/Studio/My Library
    Daz 3D/Studio/My Daz Connect Library
    for saving/manual installs and for Connect installs respectively.
    Thank you, Richard.
    You are very appreciated.
    R
