Retaining IRay Data when saved as 3Delight
bobmale
I just accidentally saved an IRay render I was setting up, as a 3Delight render. I closed it and I opened a second file to make a quick render for an image I was editing. When I returned to the first image I switched the Render Engine back to IRay. All of the information for IRay was lost. Rotations, Ground Position, the HDRI map, Progressive settings, everything. I would really like it if the save files could retain the IRay information regardless of what Engine was set when saving.
I would expect the (temporarily hidden) iray settings to save with the scene, even if it was set to 3delight - that may be worth reporting as a bug, assuming it is otherwise saving the settings.
