Problem with eye white disappearing
DarthD
Genesis 2 characters, eye white disappears when rendering with IRAY. I've gone through surfaces and everything for the eye has opacity at 100% except for eye reflection which is at 0. If I increase eye reflection then the iris and pupil are covered and the zero setting is default anyway.The third picture shows the eyes with all skin opacity at 0. Not having this problem with Genesis but it is also happening with Genesis 3 and Genesis 8.I can load a new scene and the eyes show up fine but if I load any pose that was saved in the previous scene, the eyes disappear. Once they are gone, I can't get them back even by resetting the pose, deleting and reloading the character or even loading a completely new character. I know the 'easy' fix is to just start over with this scene however I would like to figure out what is causing this because I don't want it to happen again. I have put a lot of time setting this scene up for animation by crating, loading and aligning a lot of aniblocks so starting over will waste all of that time, especially if it happens again in the future.
Is your character positioned some distance from the center of the scene - the place where the character loads by default?
there's a bug that causes the whites of the eyes to go black if the character is moved too far away from the central point. Haven't seen any cure for it mentioned othe than putting the character back at the center and moving all the scenery relative to the figure's location.
Thats it! I moved her back to center and the whites showed up again. I have a huge town in the scene and had moved the characters pretty far from center for this scene. Now I guess I just need to relocate the town instead and leave the characters in the center. Thank you!
