How to select and apply a single Animate Lite frame as a pose
How to select and apply a single Animate Lite frame as a pose -
Is this possible with this plug in? or do I have to buy the full Animate 2 product.
If it is possible to use Animate Lite for extracting a single frame and applying it as the pose to the figure.... How?
If you can get the figure into that pose (so that you are on a certain frame of the animation but it is not playing) you should be able to save as Pose Preset. Then when you want to apply the pose you can do File/Merge, or else put the file somewhere where you can see it and click on it. I have Animate 2 but I have to imagine Animate Lite allows this as well.
