How do I add metadata?
Daniel BarnettDaniel Barnett Posts: 389
After I add DAZ Studio to a new PC the metadata doesn't seem to be added. Is there a way to add the metadata from a few products at a time?
Thank you!!
dbb
  • Richard HaseltineRichard Haseltine Posts: 111,268
    Is this on content copied from an older PC or on newly installed content?
  • Daniel BarnettDaniel Barnett Posts: 389
    edited October 2013
    Newly installed. Also found that there is no database folder being created. Can you tell me the name of the database file I should find inside the database folder? I'm wondering if I create a blank database file maybe Studio will populate it on next startup??
    Post edited by Daniel Barnett on
    You cannot create a blank database file yourself, DS should create these if they are not already there, using the CMS (Content Management Service).
    You need to make sure that CMS is running as a process in the Task Manager first, as that may be your problem.
