how to make primitive invisible but reflect light?
I made a small reflector, right next to my model face and I want it to reflect light, but not be visible in the render. I tried all the settings I could think off without success!
I am rendering with Iray if it changes anything.
Thx!
  • dracorndracorn Posts: 2,379
    After you have added luminance to your object, set the Cutout Opacity of that object to zero.
    almost zero.
    This was just a normal plane made via the create primitive menu item, it does not have luminance in the surface menu. Or is it somewhere else?!?
  • I think the suggestion is to apply the Emissive shader preset to your reflector, assuming you mean in the sense of a photography reflector bouncing light onto a subject (and that you are rendering in Iray).
  • Great, it kinda work. I used to do a lot of portrait photography, so it is more natural for me to recreate my setups. But with the Emissive trick, it worked.
    On the other hand, I dont undersntad why, when I was in the surface menu under Iray, searching for Emi did not show the Emissive Shader. I had to find it manually. Weird and caused me a lot of waste time!
    Thanks!
  • In the Editor tab or the Presets tab?
  • FishtalesFishtales Posts: 6,232
    When a primitive is used in Studio it is loaded with the DAZ default shader which is for 3DLight and there is no Emissive channel but selecting it in the surface tab and using the Iray Uber shader adds it to the surface.
    True in 4.10.0.123, but the 4.11 cycle is chnaging that to use the default sahder for the current render engine http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log#4_11_0_191
    Thanks Richard. I haven't used 4.11 for a while so haven't noticed that but I'll look next time smiley
