Turning a Shaping Morph into Pose Morph
wancowwancow Posts: 2,708
There are a couple of morphs that SHOULD be Pose Morphs, IMHO.
One is the Iris Diameter morph. That should absolutely be a pose morph.
Is there a way to alter the morph to turn it into a pose morph?
  • Richard HaseltineRichard Haseltine Posts: 111,988
    You can use the Property Editor to change the grouping and location of a parameter. Then you need to resave the morph, File>Save as>Support Asset>Morph.
  • wancowwancow Posts: 2,708
    Richard, I can't seem to find the property editor... :(
  • adamr001adamr001 Posts: 1,322
    See below
    143 x 100 - 3K
    Also, if you don't have the right tool bars open, Window>Panes(Tabs)>Property Editor.
