Irony of Ironies: My PW Ghost is Invisible!
TallulahdahlingTallulahdahling Posts: 387
So I've purchased and installed PW Ghost in D/S 4.6. I've looked in all the places where the documentation says it should be, but it's not there. I've even looked in "Smart Content" and other places the documentation didn't mention, and the only place "PW Ghost" appears on any list is under "P" in "Products". But when I click the name in the Products list, no product appears.
Spooky.
Maybe I need to reinstall it manually?
  • LindseyLindsey Posts: 2,017
    edited October 2013
    I recall an issue with the pwGhost metadata not loading automatically when installed via DIM. I resolved it by manually loading the metadata via the Content DB Maintenance menu. It should look like this in the P menu.
    550 x 741 - 65K
    Post edited by Lindsey on
  • TallulahdahlingTallulahdahling Posts: 387
    Thank you, Lindsey! I'll see if I can figure out how to do that. :)
    I suppose a de-installation and a re-installation via "manual" is the way to go. (I'm fairly new to D/S. I was a Poser user until a couple of months ago.)
    edited October 2013
    If you wanted to try and manually load the metadata...
    In my picture above:
    1. Click on the white page icon with the tiny black arrow shown on the upper right corner.
    2. Select Content DB Maintenance menu.
    3. Enable the check box "Re-Import Metadata...", Click Accept
    4. You'll get a screen list of your Metadata files. Click on the two check boxes on the FAR LEFT which will Un-Check everything.
    5. Scroll down the list and look for "DAZ 3D 4345 pwGhost" and enable it's check box.
    6. Click Accept.
    Check the Content Library>Products>P and pwGhost should be populated (hopefully)
    Ah! I figured out what you were talking about, and all is well. Thank you, Lindsey! XO
