Dublicate Formula even at G3M
Lonesome Cowboy
Hi,
today i detected that my G3M has the dublicate formula error even in the G3M Base Figure.
I de- and reinstalled some morphs / characters and at least G3M base, but this didn't help.
I can't find out what figure causes the problem because in the log-file the entries of errors are a lot and seem to be randomly.
Sometimes there are even MySQL-commands listed.
What can i do to fix this?
If a moprh has duplicate formulae, or if two morphs conflict, then it will affect all loads of the base figure since the formulae haev to be read in (otherwise DS wouldn't know what to trigger when you set a morph). If you look just for lines containing the word "duplicate" that should find one the relevant files, then the question is wherther it is wrong in itself or is clashing with another property loaded earlier in the sequence.
