Looking for a room with round windows
I am looking for a interior with round windows something like this.
Any ideas?  I have looked around and so far haven't found anything.  But I know often not every angle on a product is shown.
  • Charlie JudgeCharlie Judge Posts: 13,662
    Not a complete room but The Nook has a round window.
  • Close but not quite.  Thanks for the suggestion though. :)
  • srieschsriesch Posts: 4,243
    do you actually need to be able to see through the windows?  I was able to add portholes to a room once and then simply apply part of a sky image to the flat surface of the porthole to give the illusion of one.
  • Yes I do as I need to see a character peeking in.
  • ReneWReneW Posts: 151
    The only round window I know of is over at Renderosity called All Round Living.
  • With an outer frame that thick, you could probably place a prop over a square window and have it cover the other frame from an existing room set. Maybe try a torus and a couple of stretched cubes as a proof of concept.
    I could model one in a short time - you'd need to use shaders to texture it - let me know if you want that :)
  • CybersoxCybersox Posts: 10,026
    Like this?  https://www.daz3d.com/z-meditation-room or this https://www.daz3d.com/z-clock-tower-loft-poses
    Or, if you want somthing smaller or less complex, the easiest thing to do would probably be to just take an existing set with a blank wall and add a hole by painting a round white circle on a black background and inserting it in the opacity (3dl) or Cutout Opacity tabs under surfaces, then frame the "window" with the frame from a picture frame or mirror
    Yes I am starting to think that is the way I will have to go.  I think I will give it a shot first, I haven't modeled in quite a while but hopefully it is like riding a bike. :)  I was hoping I could just find something that would work.  Oh well, time for plan B.  If I run into problems, I will shoot you a message.  Thanks for offering. :)
    The Mediation room could work if I could rework it into a four pane window.  But it would (should) be easier to make my own.  I DO like the clock tower loft though, not for this project but I can definitly use it for others. Thanks! :)
