Having problems when manually loading MetaData Files.
Michael Callahan
No matter what I do when attempting to manually load a MetaData File it seems not work. What is the proper way to load this file when manually loading the files?
You mean the files in \Runtime\Support?
I am trying to set up library files, that are for Daz Studio, I am good with poser files but when it comes to DAZ studio library file I have a hard time with the Data Files. These files have no loaders, and cannot be installed by the Install Manager.
Looked in Help and wiki but nothing there to tell me how to do this.
I like the concept of the Data file.
Thanks for Responding.
What you're looking for is: Content DB Maintenance Menu>Re-Import Metadata.
On the screen that shows the list of metadata files (stored in Runtime\Support), uncheck the far left check boxes to uncheck everything, then check the specific metadata files you want to re-import.
Thanks I will give this a try. I don't use smart content with DAZ studio, but I believe this is in the content library as well. Just hard to break old habits from starting out when the first Daz studio was out.
