How do I reveal the buttons behind this tab?
Just following a tutorial on creating layouts but noticed a small problem - https://imgur.com/a/e79nrgn
When I minimise the panes the buttons reveal themselves, but when I extend them they show in-front of the buttons I want to see instead of next to them. It's a difficult problem to describe, but basically how do I make it so that the viewport in the center of the screen resizes when I extend the right-hand tabs instead of being behind them?
  • NorthOf45NorthOf45 Posts: 5,896
    That's a fairly well-known issue. The Viewport needs a certain minimum size to show the controls. If you minimize the tab panes on the left side, or make both sides a little narrower, you should be able to see the controls.
    Close the two Shader related tabs.
  • This is a screenshot of said video for layouts - https://i.imgur.com/4Xztrxf.png
    Notice both sides are expanded and the viewport buttons are visible. Clicking to hide the left panel does show the buttons though. :/
  • It depends on the screen resolution. jestmart is correct, close the Shader Mixer/Shader Builder where theye are docked with the Viewport.
