Error to Install Benjamin for M5
mohd_yaserarafatmohd_yaserarafat Posts: 0
Hi,
I have a problem to install Benjamin for M5 to Daz Studio 4.6.
When I run the installation execution file to install, it prompts me a warning that says :
"Benjamin for M5 is an add-on for "Genesis" and they must be installed in the same location. Please choose a different install location or install the required products first"
I used a default location when I first installed Daz Studio 4.6 which is as below. The "Genesis" file is under that path as well.
C:\Users\Naruto345\Documents\DAZ 3D\Studio\My Library
I'm really a newbie on this, please help.
  • frank0314frank0314 Posts: 15,111
    Moved to the DS Forum since it wasn't a Poser related question
  • Richard HaseltineRichard Haseltine Posts: 111,612
    Since it's a Michael 5 character it may be looking for Michael 5, not the base Genesis. It's also possible it is looking for a different version of the files. You could try downloading again - since it's an installer it is presumably one you've had for a while, I'm pretty sure the current version is a Zip (that can be placed with the Install Manager if you don't want to manually unzip).
  • mohd_yaserarafatmohd_yaserarafat Posts: 0
    Thanks Richard. Problem solved.
