Lip Sync problem
Hi, I m using 4.10 Pro 32bit. When i try LipSync it said" No configuration file was found for te current figure.Do you want to browse for one, or use the defalt?" and it fail no matter which file i use or use default. Can you Help me?
following error " Some channels defined in the current configuration file could not be found on the figure. Lip_synching may not be as accurate as expected. See the log file for details".
Pls help! Thx !!
