Photoshop can´t read 3D anymore!?!?! pls help!
octobusoctobus Posts: 117
hello,
i am using photoshop cs6 and it allways worked nicely to work on 3d models in there
i was using the bridge to DAZ studio as well
it could read obj, and u3d formats perfectly
now for some reason photoshop does not understand these formats any more
the bridge works only to import a rendered image but it cannot import the u3d format from daz anymore
i am not aware of any changes i made in settings or so...
now i am confused
does anyone know what that could be?
thanks very much response
o.
  • Richard HaseltineRichard Haseltine Posts: 111,363
    If you were running the basic version in 30-day trial mode it would have acted as Photoshop extended, but when the trial ended and you entered the standard serial you would have lost the additional features - including, as I recall, all 3D features.
  • octobusoctobus Posts: 117
    nooo... it´s i fully bought cs6
    but i found it: in the settings there happend a change that i didn´t make
    use OPEN GL was unclicked and there my machine couln´t read 3d objects anymore
    i have no idea how and why that happend... i am pretty sure i didn´t make it
    thanks anyway
  • JaderailJaderail Posts: 0
    The Last Photoshop 3D bridge update I received from Adobe for CS6, not that long ago, turned the OpenGL off at install on my PC. If others are having issues with the Bridge I suggest you check your PS settings for that as well.
