DSON Importer Freezes Poser.
I installed Poser 2014 pro (64bit). Windows seven six core/Huge ram high end machine
I do ALOT with Genesis so I Installed the genesis starter essentials.
Now, i do have an extensive Genesis library so I expected delays and slow behavior.
However, every time I try to select the Pose/Materials (etc) tabs in poser after loading Genesis, the selected tab never refreshes
The main interface still works, but i can't get the material/pose tab to refresh even after twenty minutes.
It was such a pain in the neck, i had to uninstall the DSON. Now, if I load anything else but Genesis, Poser works fine.
So i'm back to using the cr2 exporter in DAZ as a workaround.
Does anyone have any tips about this issue?
DorianC
Thread moved to the Poser forum for better answers to the question asked
The Poser library uses Flash. Do you have the latest edition of Flash installed?
Did you install Service Release 2.2?
http://poser.smithmicro.com/pro2014-updates.html
