How can I create a shader (Iray light) in Daz studio?
Hello,
I'm trying to create a light shader (daz studio iray), but, I'm lost in this fight.
My attention is on having these options on the surface tab:
1- lumens (flux)
2- color temperature
3- diffuse color / or any other option that changes the color of light ... Along with color temperature.
I have some shaders lights, like those of nvidia materials (mdl).
I also have the emissive shader that comes by default in daz studio.
But I wanted to create a shader that had the parameters (lumen flux, color temperature, and a third option that could change color like when applying a diffuse color to a model.
In Mix shader I can not find the lumens (flux), or color temperature ...
when I add a light in the scene (menu / create / light), I can see lumens / color temperature "of that light", but in the PARAMETERS tab ... This does not appear in the SURFACE tab ...
... How could I have lumen flux, color temperature, of a light, on the surface tab? ... Without copying the work of others?
Thanks
  • 3Diva3Diva Posts: 12,058
    As soon as you turn the object's "Emission Color" to white (or any other color other than black) in the Surfaces Tab you should see new options pop up under it in the surfaces tab that let you change the emission temperature/color, luminance, etc.
  • ArtiniArtini Posts: 10,900
    edited January 2019
    If you apply iray UberShader to the surface and change "Emission Color to something else, than Black,
    you will see that the surface with such material will emit the light.
    It was easier for me to switch "Luminance Units" to "kcd/m^2" to see the light with default values.
    I have left "Base Color" and "Glossy Color" with White, but have noticed that changing "Base Color" to the same as "Emission Color"
    will give even better light. Please look att my surface settings and an example render with them.
    440 x 1028 - 105K
    1300 x 1000 - 148K
    Post edited by Artini on
    edited January 2019
    Lumens does not take to account area of the light surface, so it is harder to find the value, which works well.
    Ok, switched Rendering Settings to "Scene Only" and "Enironment Intensity" to 0, to see that the surface really produce the light.
    1300 x 1000 - 121K
    edited January 2019
    Just made a test with 3 spheres with diameter 1 cm, 10 cm and 50 cm
    and applied to them the same emissive material with "Luminance" of 805 lumens and "Emission Temperature" 2700 K.
    As you can see the light is getting weaker, if the area of the emitting surface is getting larger,
    and one uses lumens as "Luminance Units".
    1300 x 1000 - 100K
  • Many thanks for the tips.
    I'll test what you suggest, and tomorrow I post the result back here.
    One thing I need to say:
    When I create / add a light (menu / create / light), the "lumens (flux)" and "color temperature" are there in the tab parameters ... These properties do not appear on the surface tab , just in tab parameters.
    But I'll test and I'll come back to you.
    edited January 2019
    If you create a light using (menu / create / light) the "lumens (flux)" and "color temperature" are there in the tab parameters,
    but I thought, that you wish to change the surface to allow it to emit the light.
    There are two different ways to create light sources in Daz Studio:
    1. Create a light using (menu / create / light)
    or
    2. Choosing the surface of the object and applying to it iray Uber shader (or mdl from example Nvidia materials)
    and then changing "Emission Color" to something else, than Black.
    Please post a screenshot of your surface tab, to see what is the difference to the one, I see on my computer.
    or
    or
    Hi
      Here nvidia vmaterials lights, these lights derived from MDL have their lumens (flux) and color temperature on the "flap surface".
    I know I can copy / save this shader, and then have my shader with lumens (flux) and color temperature ... But I wanted to know how to create these options, instead of copying them ...
    The emissive you mentioned, I'm going to give you another test on them today and see if I get close to what I wanted ... I'll get back to you today
    1920 x 1080 - 334K
  • Indeed! you're right!!!
    I applied an emissive shader (that emissive iray pattern that comes with daz), although, the options have different names, this seems to work using:
    "Luminance units = im"...
    edited January 2019
    This is a product I purchased a long time ago before I knew what I was doing but then realized it was very to do yourself. If you want something easy that you can also learn from, you can get https://www.daz3d.com/simple-emissive-light-shaders-for-iray
    Post edited by Wonderland on
  • This is a product I purchased a long time ago before I knew what I was doing but then realized it was very to do yourself. If you want something easy that you can also learn from, you can get https://www.daz3d.com/simple-emissive-light-shaders-for-iray
    Thanks for the tip. I've been using iray shader since 2017, but I've never tried to create one on my own. And those bricks of the mix shader ... I was kind of lost.
    The fact is, I do not want to illuminate anything! What I want is to use the light shader to color / paint / replace the texture of a 3d model with the light shader ... For in order to create flat style cartoons vectors, in the iray render of 3d characters etc etc ....
    a flat 2d look of 3d models.
    I'm finally getting it.
  • jorge dorlandojorge dorlando Posts: 1,159
    edited January 2019
    Here, the first results of 2d look,the 3d model, and then its render look 2d style after light shader emission / config :
    1965 x 1267 - 551K
    1965 x 1267 - 741K
    Post edited by jorge dorlando on
  • And here another:
    1730 x 1534 - 451K
    edited January 2019
    Nice. I did not thought, that such a shader could give the object flat, cartoon look.
    This is another approach to get the NPR look, which is great.
    Sidenote;) As a person who doesn't use IRay, kind of baffled by the fact a larger surface emits weaker light. Is not this a pbr renderer? surprise
  • EsemwyEsemwy Posts: 578
    “Luminance” in Iray can be applied using several metrics. Lumens in particular are not dependant on the size of the luminous surface. The surfaces in your picture are putting out the same absolute amount of light with that light being spread evenly across the surface. See this explanation.
    Ok tks for explainingyes
  • Oso3DOso3D Posts: 15,116
    In my Oso Toon, this is how 'flat color' is achieved; it sends the normal color map to emission color and adjusts it so you get, well, a flat color.
    Though the way I have it set up, it doesn't have shadows, so that's interesting.
  • here a render standard iray, and another style flat of emissive shader  :
    1920 x 1080 - 117K
    711 x 400 - 268K
    edited January 2019
    It´s will work fine for motion graphics
    I forgot how to post images in body text, instead of this tumbinals
