Need Assistance Locating A File
SixDsSixDs Posts: 2,384
I usually don't like to bother anyone unless I'm at a complete loss, but it seems that I am. I am trying to locate a file containing a breast adjustment utility or script that I know I had from several years ago. I distinctly remember playing around with it at the time. But I don't seem to able to locate it amongst my content anywhere, nor do I seem to have it installed in any content library. My efforts to locate it are hampered by the fact that I do not recall exactly what it was called or who made it, so my search efforts both on my local machines and the internet have failed to turn it up. I do have two of Sickleyield's products but neither will do for what I am attempting, unfortunately.
Here is what I do know, or am reasonably certain of:
It was a breast/cleavage adjustment utility to compensate for shrink-wrapping in the chest area;
It was perhaps three years or more ago that I may have obtained it;
It was either free, or perhaps a Beta, not a purchased item
It worked much like a set of deformers, displaying adjustment points that could be used to manipulate different parts of the chest area.
Does that ring a bell with anyone, and, if so, can you tell me what it was called or a filename so I can locate it, please? I know that it has to be somewhere here but I have failed with any logical search terms that I can think of to locate it. (It doesn't help that Windows search hasn't worked properly since XP and results tend to often be swing and a miss).
I appreciate any assistance offered. Maybe your memory is better than mine? smiley
  • nemesis10nemesis10 Posts: 4,054
    Try looking through Sickleyield and Zev0 products withhide purchases unchecked.... they are the most likely possibilities...
  • Dunno about freebies but Zev0's Fit Control can do what you describe (and more):
    https://www.daz3d.com/fit-control-for-genesis-8-female-s
    https://www.daz3d.com/fit-control-for-genesis-3-female-s
    ^There are male versions and bundles too if you want more.
  • SixDsSixDs Posts: 2,384
    Thanks, folks. I appreciate your taking the time to reply. However, I am looking for something that would work on an older V4 item, and I was certain the mystery utility I am referring to was generic. But I thank you anyway.
  • MelanieLMelanieL Posts: 7,889
    There are a couple of candidates mentioned in this thread: https://www.daz3d.com/forums/discussion/41144/breast-fixer-for-v4
    Thanks, Melanie. I was hoping that my vague recollection of that mystery utility I referred to was the answer, but it turns out that it isn't. Just in case anyone is wondering, I did track down what I had been thinking about - it turns out that it was free, but only part of a larger set and for G3F, by albiejee over at rendo. I already have three other solutions for this for G3F in my content library, so it was a dead end in regards to what I needed. The thread that you linked does give some food for thought, including some ideas that I was already toying with. Maybe a collision object that will deform the mesh, then save the results as a preset or morph. Since it is a legacy rigged item, I may be better off pulling it into Poser first and working there. I'll come up with something. Thanks, everyone.
