Question on..... Leather Collection Merchant Resource - Vol1 (PBR Textures)
Question on this item and others similar: Leather Collection Merchant Resource - Vol1 (PBR Textures)....., by Isource textures.
This is called a merchant resource, but does this mean that it can be used in DS like other texture additions, where simply one click will apply the rexture to the object?
Could you also please speak to this idea in general, items used as merchant resources?
Thanks.
  • thd777thd777 Posts: 946
    Based on the description, the set contains just the texture maps. To use it, you will need to set up your materials yourself, for example based on the Iray uber base shader. It is not a simple one-click material setup.
    Ciao
    TD
