Christian Mixable Expressions: Install Failed? [SOLVED]
LosingSignalLosingSignal Posts: 409
edited January 2019 in The Commons
Has anyone successfully installed the EmmaAndJordi expression pack?  After multiple deletes and installs through DIM, I'm still getting an "Install Failed!" on the Ready to Install tab.
Post edited by LosingSignal on
  • nemesis10nemesis10 Posts: 3,996
    I install differently; I download the Daz Connect file and Daz connect authorization file from the Product library, put them in the Install flolder in the Cloud folder in the Data folder of the Content folder and then tell Daz Studio to install offline package.  Nonetheless, the product does work.
  • I missed that it was Connect, too. I am in the "refuse to use Connect" camp. Ah, well, they will be usable in a year, right?
  • NorthOf45NorthOf45 Posts: 5,878
    It's not an issue about Connect. There is extra data after the end of the archive. 7-Zip gives a warning if you click the info button, but no errors if you test it. I used a hex editor to trim the offending 6 bytes off the end and it installed properly with DIM. DAZ needs to repackage the archive.
  • ButchButch Posts: 800
    I had the same problem.  I gave up and manually downloaded and installed it - it works manually.
  • xyer0xyer0 Posts: 6,502
    Same problem for me. I'll wait for the update.
  • Just tried it again.  Looks like they fixed it.
