Good Nurse/Bad Nurse textures error
SloshSlosh Posts: 2,391
I have the Mad Nurse outfit for Genesis 2 Female and also have the Good Nurse/Bad Nurse texture set. When using the presets to apply any of the textures, I get the following error: Missing Files and a reference to /data/Ravenhair/MadNurse/MNrCape/UV Sets/Ravenhair/Base/default.dsf, which I do not have because I bought the G2F version. The textures still load, but the error message is annoying. If I change the data folder to say MadNurse instead of G2FMadNurse, then the error comes up when loading the actual clothing items and the default textures.
Of course, I can copy the entire MadNurse folder and change all of the folder names to without G2F at the beginning, but then I have duplicate folders on my hard drive. Is this the solution?
  • Cayman StudiosCayman Studios Posts: 1,139
    I raised the issue of the MAT files throwing up a Missing Files dialog in a Members Only thread. Mad Nurse for G2F has now been updated and it seems to work OK. I don't have the Good Nurse/Bad Nurse textures yet, so I'm not sure how they will work.
  • SloshSlosh Posts: 2,391
    I installed the update, but as you said, it was for Mad Nurse, not GoodNurse/BadNurse, which is the product giving the error now. That needs to be updated. I ended up making a copy of the data folder and changing the names for each folder so that the presets would have somewhere to look. No more error.
  • JGreenleesJGreenlees Posts: 2,249
    I am working on the update. Usually if you apply the texture then just click through the error the material will still apply.
    But I am getting that solved.
