PSA: There is a free tool called Battle Encoder Shirasé that can easily help you manage CPU usage
Not sure if anyone else uses it, but I've been using it for a couple years now. I like to browse the internet while I render but DAZ likes to take everything you give it. By using this tool you can liimt individual programs usage of the CPU and it works like a charm for DAZ. Obviously, you should expect a speed impact on your render.
http://mion.faireal.net/BES/
  • nicsttnicstt Posts: 11,715
    It is rediculously easy to set afinity manually.
    Unknown tools, I'm wary of
  • namffuaknamffuak Posts: 4,521
    I just use a desktop icon to set priority to 'below normal' - if I'm not doing anything else, studio gets the whole cpu; if I decide to play a game or video, or browse the web, studio gets what is left. Works quite well.
  • Well if you are rendering Iray you aren't using your CPU it's the GPU you are using, so no use messing with the CPU as it will have no effect !
    Different story for 3Delight it uses the CPU in renders!
  • PetercatPetercat Posts: 2,324
    Unless you have a larger scene than your GPU memory can handle.
    Then you're rendering Iray with your CPU.
