G8 Female Default Thigh Side-Side Pose Problem
Hi Everyone! I have a problem with one of my characters which is derived from the Genesis 8 Female base character. I'm not sure how I messed it up, but it now loads with both the Left and Right Thigh Bend | Side-Side settings at -9.18 and +9.18 respectively. Once I zero them out they emulate the correct default GF8 positions. However, the parameters are not the same as the default, so switch back to the incorrect numbers (relatively) after applying different poses. I screen captured both the incorrect and zeroed states of the Parameter Settings with the 'Keys" tab selected, which shows the incorrect Raw values.
I would greatly appreciate some advice about how to fix this, if possible. Thanks in advance!
675 x 761 - 169K
677 x 783 - 176K
I suspect if you find their entries in the Property Hierarchy pane and look under controllers you will find unwanted ERC links. If so you can right-click to delete them.
Solved! Thank you so much for your guidance. I had to do some drilling but found the culprit. Works fine now!
