3Delight Shader - How do I make it work?
Hi.
I bought some shaders (https://www.daz3d.com/industrial-walls-daz-studio-shaders), but I cant make them work. In the product information, it says "Required Products: None", and it does not menshion anything about the shaders beeing 3Delight format, so i thougt that I could use it.
In Daz, my new shaders are catagorizied under "Shaders/3Delight". That is why I guess it must be in a 3Delight format.
I guess I need to change from the Iray render engine to a 3Delight render engine, but how do I do that?
I can make Iray shaders work.
Kind regards
Jesper
In the Advanced or Editor tabs of the Render Settings pane there is a button labelled Render Engine - click that to get a menu of the available engines. In general, if a product has an SKU in the low twentry-thousands or under any DS materials will be 3Delight only, and won't specify as at the time that was the only engine (other than OpenGL) suported.
Shaders are usually specific to an aplication and render engine, though that is improving. I would not expect to get a 3Delight shader working in another application - at best you might be able to use Shader Baker to produce a map that matched the look under particular lighting.
