about stephanie
ultima9999ultima9999 Posts: 0
hi guys
i have a question about Stephanie 4
i want to buy the character , but i'm not sure which version i should buy.
i charged some money on my prepaid credit card , i spent a part of them for product on rederosity store (the one that requires SP4) and i'm considering to buy also the reality 3 plugin for poser , i'm now short of resurces and i can't afford the pro bundle and the starter pack (both of this packs also contain manuy things i don't need to be honest), so i'm thinking to buy the elite base pack.
what i need is V4 to Sp4 and i've seen the elite base contains a character .cr2 so i'm not sure it is the morph i need or a separate character.
    Steph 4 is a character for V4, rather than a standalone figure, so in order to get any character pack working you would need V4, probably her morphs++ pack and also Steph 4
  • ultima9999ultima9999 Posts: 0
    thanks for the reply Chohole
    so , i have V4 , base morph inj , elite morph inj and ++ morph inj , do i only need to buy "Sp4 elite base pack" ?
    this is what i need according to the readme file of the product i bought
    "Needed Files List and System Required:
    Poser 6 & up or Daz Studio 3.1.2.32 and up (including DS4 and DS4.5), Daz Victoria 4.2, V4.2 Morph++, Elite, and Stephanie4 for V4."
    edited October 2013
    Yes, AFAIK. It is all I bought when she came out.
    Post edited by Chohole on
    thanks alot !
    i bought SP4 elite base , and i think there's something i did'nt think of , is it possible thaqt the pack i bought is not compatible with V4.2?
    because when i apply injections not all of them seems to work , petite deformer does not .
    i can turn the dial only from -1 to 0 and nothing seems to change in the figure.
    but , when i try to use the product i bought from renderosity the proportions won't change on the figure.
    the product i bought is Lucy Zepp and the character can be used with 4 age settings , when i inject the morphs , the proportions change , but the final result looks like and adult child and not just a child.
  • fixmypcmikefixmypcmike Posts: 19,738
    How did you install S4?
    as always , copy runtime folder from zip archive and paste into poser's root folder
  • Richard HaseltineRichard Haseltine Posts: 111,972
    Did you run the \Runtime\Libraries\!DAZ\DzCreateExpFiles-v4.bat file?
    edited October 2013
    i use poser since poser 7 and never had to do something like this before , i did it right now , going to check if everything works now then i will report
    seems to work fine right now , thanks !
    Post edited by ultima9999 on
    The Bitrock installers ran the utility for you, as DIM does, but if you manually unzip there's no code running to trigger the process so it has to be done manually.
    i see.
    many thanks
