Eyes are acting weird(black in corners)
Don't know how to describe it so I attached a picture. What could be the cause of those black areas? Eyes used to be normal.
1280 x 720 - 103K
Which figure is that?
Genesis 8, custom
this is usually caused by moving the character away from the world origin. In DS 4.11 Beta, it is exacerbated by setting render instance optimization to Memory, even if you aren't using instances in your scene.
https://www.daz3d.com/forums/discussion/comment/4231276/#Comment_4231276
I am actually having this problem in 4.10, thanks for your help, moved the scene to the centre, seems like it solved the issue!
4.10 seems more forgiving than 4.11 Beta, but moving to world origin is the tried and true workaround. I'm glad that worked for you.
