Is function.bind gone?
kabexef
I try to connect a bound function to a signal to get my old context back. Unfortunately i get the error 'TypeError: Result of expression 'fctn.bind' [undefined] is not a function.'.
var bbb = {
"txt": "BBB-Text",
"p1": "BBB-P1",
"go": function(localThis) {
print("Function Code (this): Text = " + this.txt + "; p1 = " + this.p1);
print("Function Code (bbb): Text = " + bbb.txt + "; p1 = " + bbb.p1);
print("*** BBB GO ***");
bbb.go();
print("*** FCTN GO ***");
var fctn = bbb.go;
fctn();
function anotherFunction() {
print("anotherFunction");
var timer = new DzTimer();
timer.timeout.connect(anotherFunction);
timer.timeout.connect(bbb.go);
timer.timeout.connect(fctn);
timer.timeout.connect(fctn.bind(bbb)); // TypeError: Result of expression 'fctn.bind' [undefined] is not a function.
print("*** TIMER START ***");
timer.singleShot = true;
timer.start(100);
// sleep... // keep script alive while timer is running
Ok, the workaround (directly referencing the defining var) will work ... but is not what i wanted.
Post edited by kabexef on
