Question about HDR Pro-Set Yosemite Pack 1
TallulahdahlingTallulahdahling Posts: 387
When I click on one of the Yosemite thumbnails, the set appears, but the whole floor of the set is grey, so that I can't tell what feature of the environment is where. Is there some way to "turn on" the floor images so that I can know what I'm doing? I'm working in D/S 4.6.
  • JGreenleesJGreenlees Posts: 2,249
    edited October 2013
    Opps re-read.. The ground does appear grey. What i did was make it a bit more transparent.
    Post edited by JGreenlees on
  • LindseyLindsey Posts: 2,017
    edited October 2013
    I turn the DT-GroundPlane invisible on the Scene Tab (toggle the EYE icon), then you can position the characters and spin the DT-DoubleDome to your liking.
    Before rendering, make the DT-GroundPlane visible and make sure the models just touch the DT-GroundPlane if they are supposed to be on the ground for the best shadow effect. I use the perspective camera and spin the view so you're looking under the DT-GroundPlane and move the model's Y Trans parameter until I barely see it poking though.
    Post edited by Lindsey on
    I hadn't thought of that.. though i had to have the ground plane so i could see it, but Mind if i paraphrase that and add it to the readme? (getting a lot of questions on this and that might help others)
    Of course Jen. Please use my comment in any manner as you see fit!
  • TallulahdahlingTallulahdahling Posts: 387
    Thanks, Jen! Thanks, Lindsey!
    Speaking of readme files.... I've only recently started using D/S - I've been a Poser user for years - and I'm having a heck of a time finding the readme files when the merchandise is installed by install manager. The freebies I install manually - no problem, I've found their readmes. But where do the other readmes go?
    Click on the letter i in a circle in DIM to go to the readme page.
    Ah! Thank you, Fixmypcmike. :)
    Okay, I tried looking for some of the readmes by clicking on the little circled "I", and it worked for some, but for a few - including the HDR Yosemite set #2 - and it came up with "page not found". For some reason the HDR Yosemite set #1 didn't even show up on my list, even though I own it and it's installed.
    Ah... the only version that I can see is the Carrera version, which I didn't install. Hmmmm....
