Weird stuff happening when importing Bryce OBJ - Newbie
rol3drol3d Posts: 40
I'm having a problem importing the Daz 'Bryce Coach' model (which comes with an OBJ and textures) in DS.
Steps:
I bought the Bryce Coach and extracted and placed the .OBJ, .MTL files and the texture folder into their own folder;
I then opened DS, selected IMPORT and then selected the coach OBJ; in the subsequent import window, I left all settings except I set the ‘From:’ section to Bryce.
The Coach imported … but is not visible (only the bounding box is visible); however when mouse-overed I see a complete highlighted wire-frame of model. I even added a light nd still no shaded version.
It looks like it found all the textures: The texture image shows in the 'Diffused Color' section of the 'Surfaces' tab.
Even rendering doesn’t bring it out.
Thanks for any help!
  • DAZ_cjonesDAZ_cjones Posts: 658
    Steps:
    The surfaces all come in with the opacity set to 0%. If you go to the surfaces pane and select the materials you can change the opacity to 100% and the bus will show up.
  • rol3drol3d Posts: 40
    Thanks so much - that was it! Thanks so much for the info.
