Multi select don't work in my script
Silver Unicorn
Hi this is a scriptlet, from A script I am making. It is a listbox I am filling with selected nodes of the scene. It needs to be multi select, but I cant multi select in the listbox. I try to use extended here, but I also try to use Multi. Both are not working. What is the problem?
/*********************************************************************/// Globals/*********************************************************************/var selNodes = Scene.getSelectedNodeList() // Get the selected nodes from te scenevar nSelNodes = selNodes.length; // The length of the selected node array// Create and define DzListBox: 'Surfaces'var Surfaces = new DzListBox( Dropper );Surfaces.setGeometry( 190, 21, 171, 181 );Surfaces.SelectionMode = Surfaces.Extended;for( var i = 0; i < nSelNodes; i++ ){ if( selNodes[i].name != selNodes[i].getLabel() ) { Objects.insertItem( selNodes[i].name + "/" + selNodes[i].getLabel() ); } else { Objects.insertItem( selNodes[i].name ); }}
Post edited by Silver Unicorn on
What is Objects?
There is, by the way, a forum for scripting https://www.daz3d.com/forums/categories/daz-script-developer-discussion - you may want to edit your frist post and select that from the box at the top, to move the thread there.
Yes good point Richard I copied the wrong part! This is what I wanted to show, that is not working.
Like you see I make the listbox Objects, set the selection mode, but I can't select multi lines using CRT or SHIFT
SelectionMode should be selectionMode - objects and methods usually have an initial lower-case letter. Also, the modes are static enumerations belonging to the object itself, so instead of Objects.Extended use DzListBox.Extended
Thank you that was the problem!
Bah, used the wrong term - I meat properties and methods, not objects and methods. Edited to correct that for future readers.
