Reflections
For some reason the hair from this set: https://www.daz3d.com/amber-character-and-hair-for-genesis-3-female-s doesn't show up in the character's reflection. Is there a slider in the surfaces tab I need to change?
I'm using the mirror shader from this: https://www.daz3d.com/useful-mirrors-for-daz-studio with the 3Delight engine.
Please no spam about the wonders of Iray...
You are using the 3Delight material presets for the hair ?
Yes. The reflection in the mirror is bald.
Try increasing the Max Ray Trace Depth in Render Settings
Didn't work. It's not hair in general, just this hair.
Maybe a setting in the surface tab?
Is the hair using the OmUberSurface shader? If so, check that raytracing is enabled in the surface pane, if it's disabled, you will get no raytraced reflections.
To see what shader is being used, select the hair, go to the surface pane, select one or more surfaces and check in the upper left corner of the pane, there should be the name of the active shader.
That did it. Thanks.
